Are driveshaft U-joints supposed to be notchy?
Old 09-04-15, 09:55 PM
GISguy
GISguy's Avatar
Default Are driveshaft U-joints supposed to be notchy?
I have one driveshaft that was rebuilt and balanced, with new U-joints installed (they sawed off the old ones and welded on servicable ones) that vibrates insane amounts in the car- so much so that it had to be returned.
I have another driveshaft currently in the car that was pulled out of a junker, and the U-joint is fairly notchy, and gives me annoying vibrations at 30-40 and 55-70, but is driveable.
Does it really matter if the joint is notchy? Or is it a matter of if it's too stiff?
And yes, new center bearings on both diffs.
Old 09-05-15, 01:05 PM
hmhatch
hmhatch's Avatar
Notchy/not smooth rotating u joints can cause vibration. It should move through its full range of motion without any binding. It's not ideal obviously. If the joint has play in it, I would be looking to replace that sooner than just a slightly notchy joint. It does suck that sc300 u joints are not serviceable.
GSdarksol
Suspension and Brakes
05-15-17 09:16 AM
qwerty04
12
01-24-13 03:31 PM
sinstrex
08-21-11 02:48 PM
Lettuce
10-08-08 09:41 AM
Misha98GS4
02-14-07 01:19 PM
Quick Reply: Are driveshaft U-joints supposed to be notchy?
