1999 SC300 won't accelerate?
Hi all, hoping someone can point me in the right direction here.
I was driving my SC yesterday when all of a sudden I noticed it wouldn't accelerate. Idle was fine, but I did get a check engine light. I pulled over, popped the hood, all looked fine, no obvious leaks or anything. Pulled the throttle cable, no response. I shut the car off, then started it again, and I was able to drive a little ways normally, but then it happened again. The only way I was able to get the car moving again was to completely floor the pedal - like past the kickdown point - and even then, I wasn't getting full power.
I got it towed to a shop near my house, and what they're telling me is that I need a whole new throttle body assembly because of failed sensors - which would cost me $1900!!! If that's the case, I'll be buying a new car asap, lol. I asked him if the sensors couldn't be replaced, but he seems to think they don't sell them separately.
I'm going to get a second opinion, but does this sound legit to anyone?
Super Moderator
Tell them to stop guessing, lmaol. You have an odb2 car so reading the error codes should be easy. If it was a sensor it will throw an error code. What error code did they get that tells them a sensor is bad ?
Depending on whether you have traction control , there are three or four components on your throttle body has electrical connections .. TPS , Sub-TPS, IACV and Traction control Motor.
You should have a CEL light with an error code.
Check your cat converters that the honey combs haven't collapsed inside which restricts exhaust flow that can cause you not revving higher and have power.
I took it out from that shop and took it to a dedicated Lexus guy (he's factory trained). Cant remember the exact details, but he said this is not an uncommon issue, and he thinks cleaning out the throttle body and potentially replacing the sensors should take care of it. He did pull the codes - when I speak to him again I'll get the exact details and update the thread
Ok, update. Cleaning out the throttle body fixed the issue, but apparently I have a bad accelerator pedal position sensor, which is apparently $505. A lot better than the $1900 I was quoted, and they assure me that that'll fix all that ails me. Anyone know where I can potentially get one cheaper?
Is this it?
Super Moderator
If I were you I would ask them for the part number so you are sure of what they are referring to .
But yes it looks like it since that is the lever for the throttle cable . There is a sensor there which is the accelerator pedal sensor. It tells the engine ecu how much have you pushed the accelerator which determines how much the throttle body plate is opened.
I have the sensor
I had the same exact issue. I have a sensor that works if you need it. The accelerator pedal position sensor, the $500. Message me if you still need it. We can work out a fair price, I just want what I paid for it. I also have a complete throttle body if you need it.
Already got it fixed, it was the APPS. Thanks for the follow up though guys - the car drives better overall now, and in hindsight, it had been on the way out for a while, because I'd always noticed a dead spot in my pedal travel previously
