Rear unstable in rain on bumps. Stock plus Torsen/R154
Hi,
I drove my NA/T project for the first time today in the rain. I drove like a Granny and stayed clear of boost RPM's. I noticed the car tracked fine on smooth roads but It felt like the rear was all over the road on bumps in the rain. It tracks straight over bumps on dry pavement. It feels like it is sliding left and right over bumps.
The car has BC racing coilovers. All new front end parts and bushings etc. but the rear suspension has had nothing done except the coilovers. The bushings and control arms are stock with 70K miles on them.
I have a bad Torsen but i don't think that is part of this issue.
What keeps the rear of my car tracking straight over bumps? Whatever this is must be failing.
Just last week i noticed the car was pulling left on boost. We tightened a REALLY loose bolt on the rear control arm and it stopped pulling. This feels similar but pulls/slides both ways over bumps.
All this is while driving incredibly slowly to work today. It did not inspire confidence so I drove accordingly.
Super Moderator
do you have good tires with good thread ? sh?tty tires will get you all over the place in a wet pavement... NO TRACTION !
and why the hell is this on suspension and brakes section ? I can move it for you not unless you want to discuss about its suspension and brakes ?
You might need to go to aftermarket adjustable rear toe control bars & traction bars to fine tune the rear alignment. But certain tread designs work good on dry roads but absoulutely suck in the rain under power because they don't shed the water & the tire doesn't make good contact with the pavement. Put a 80lb bag of concrete in the trunk & see if that changes things (centered)
I will say though, if I also have an alignment problem, I would suspect it made the loose LCA behave even crazier. Glad i saw no rain while it was like that. Could have been a deadly combo as today was hairy as hell in the rain, and that's with the LCA tightened.
