bouncing like rev limiter at 1500rpms
Old 10-28-15, 04:21 PM
weeters
weeters's Avatar
Default bouncing like rev limiter at 1500rpms
Any one ever have this issue? If i unplug the tps it revs fine. I hooked up my scanner and it will not read anything other than zero for tps angle. new tps set properly. I'm at my wits end. any help appreciated. i'm running tt ecu mod with 2jz gte upper intake.
Old 10-28-15, 07:00 PM
weeters
weeters's Avatar
measured my idl1 and idl2 and it has 12v at closed throttle. i think its supposed to be less than 4. can someone measure that at their tps. its the red wire at either tps.
Old 11-04-15, 05:18 PM
weeters
weeters's Avatar
Found the problem. Had to flip tps wires around when it's ffim.
Old 07-12-16, 11:29 AM
joe diego
joe diego's Avatar
So, if im running a FFIM this diagram would not be correct? I would have to swap the TPS wires?
Old 07-12-16, 12:13 PM
Ali SC3
Ali SC3's Avatar
gte and ge are flipped, so if you are looking at a gte diagram you need to flip your tps wires if using a ge tps and vice versa.
Bigdogsc
SC- 1st Gen (1992-2000)
11-15-15 06:45 PM
williamb82
09-11-12 03:41 PM
broda805
02-09-12 07:33 PM
turbodremz
13
08-27-10 09:36 AM
SC51
04-17-10 07:25 PM
Quick Reply: bouncing like rev limiter at 1500rpms
