passing smog sc300 gte head gasket/ arp head bolts
Car also had a small exhaust leak on midpipe before cat and was not driven very far before attempting smog I went for a pre test to see where the numbers would be and the guy told me it would pass
travi, thank you for sharing your results! I'm impressed it worked for an NA car. The HC's seem right on the nose but without knowing your car's service history that could also be attributable to other factors and the health of the cat. Still, congratulations!
How does the SC's pickup compare with this gasket on?
I thought it would pass just fine, yeah the HC is a little high and the Nox has dropped a little, both are due to the compression change. what do you have the timing set at? you passed just fine but if next time the HC goes over the limit by a hair turn up the timing a couple degrees (within the allowable 10 +/- 2 degrees range) and it will raise nox and lower HC a little bit.
95 Integra
Performance & Maintenance
03-04-06 12:53 PM
