throttle body gasket change?
Old 11-21-15, 06:32 PM
brad0
brad0's Avatar
Default throttle body gasket change?
doing my spark plugs next Saturday and was wondering witch gasket to replace. i bought one and then figured out there was two different ones? help would be nice!
Old 11-21-15, 08:50 PM
t2d2
t2d2's Avatar
Originally Posted by brad0
help would be nice!
Knowing which vehicle you have would be nice.
Old 11-21-15, 09:14 PM
brad0
brad0's Avatar
oh wow didnt even notice i have a 97 sc300
Old 11-21-15, 09:32 PM
brad0
brad0's Avatar
also i guess theirs three one being pretty expensive
Old 11-23-15, 11:14 AM
Shayy
Shayy's Avatar
I'm doing them on my 97 SC300 as well on Thanksgiving morning. I'm also doing my valve cover gasket and distributor O ring. I will not be replacing the throttle body or intake gaskets because they're metal and should be fine as long as you're careful with them during the job. Hope this helps and message me for any info as i'm doing the job just a couple days before you
Old 11-23-15, 04:00 PM
187's Avatar
I've had mine off a dozen times and never replaced it, just be careful with the gasket and it will be fine.
Old 11-23-15, 06:13 PM
SCFactory
SCFactory's Avatar
Done a handful of 2J NA tuneups and gaskets are always fine, you can spray em with brake cleaner and make sure mating surfaces are clean.
Old 11-24-15, 09:14 AM
Ali SC3
Ali SC3's Avatar
yeah I have never replaced the intake ones just try not to bend them too much, even then just sort of bend them back and tighten it down and it seals up every time. If they look oily/burnt then clean them off first. do valve cover gaskets and the distributor o-ring if its leaky.
Old 11-26-15, 10:17 AM
brad0
brad0's Avatar
thanks guys you just saved me money!!!
SC3G
11-14-12 07:10 AM
Dtwillis5
02-02-11 10:50 AM
acklac7
SC- 1st Gen (1992-2000)
11-26-10 06:55 PM
bubbalouie
11-03-09 08:41 PM
Quick Reply: throttle body gasket change?
