Drive shaft parts question
Hi Guys, I'm replacing the front flex coupling on my 97 SC400. When I removed it I saw there was a bushing and seal on the drive shaft end, which pilots on to a thin shaft inside the trans. output flange.
Mine is (of course) torn up. I can't seem to find a part name or number for a replacement.
Does anyone know what this part is called, and whether it is available separately? I'd hate to have to buy a whole new front half just for that little bushing!![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Any help is appreciated.
Regards,
M.R.
Regards,
M.R.
Apparently it's called a "centering sleeve" in BMW land. As for Lexus, I haven't called the dealer yet but I'm afraid they are going to try and sell me the whole drive shaft, when all I need is a bearing.
I'm also in need of a front flex coupling. That costs about $60 for every other car, but the least expensive one on E-bay is close to $200, and Lexus wants close to $400!
If anyone has any info, I would appreciate the help.
Regards,
M.R.
Regards,
M.R.
I was referring to the bushing in the center of the shaft. there is one on both ends, and they pilot on to a small diameter pin in the diff. flange and trans output flange. It kind of looks like a spherical rod-end bearing, and is retained by a metal cap. As I said in my second post BMW calls it a "centering sleeve".
As for the flex coupling, apparently the ones for the 97 models cost the most, (the bolt pattern is smaller). I have been unable to find one for less than $300 new.
Regards,
M.R.
Regards,
M.R.
