Need help on which part to order online
Old 12-07-15, 07:54 PM
DreaMzZ
DreaMzZ's Avatar
Default Need help on which part to order online
My car needs a new o2 sensor and the OBD2 scanner said the code was P0135 which is the front oxygen sensor on bank 1. Im not very knowledgeable on this type of stuff and was wondering if someone could point me in the right direction of which one to order online off eBay, amazon, etc. I really dont want to order the wrong sensor or one for a non-VVti engine. Any help is much appreciated. My car is a 2000 SC 300
Old 12-08-15, 04:37 PM
Bankswood
Bankswood's Avatar
Go to Rockauto. It will walk you through to the correct the part.
Old 12-08-15, 05:30 PM
1997Soarer
1997Soarer's Avatar
I screenshot this from the densoautoparts.com website. Denso makes the sensors for Toyota.
2000 SC300
Downstream rear is the sensor in the front pipe under the passenger foot well
Upstream front is the sensor for cylinders 1-3
Upstream rear is the sensor for cylinders 4-6
You can also try ebay and amazon. Just search "Denso oxygen sensor [part #]" and you'll find it
Old 12-08-15, 08:56 PM
DreaMzZ
DreaMzZ's Avatar
So based on the error code you think I need to purchase the Upstream Front one?
Old 12-08-15, 09:33 PM
DreaMzZ
DreaMzZ's Avatar
Im so confused... On the site you linked me it says Denso 234-4626 is an Upstream front sensor. On amazon it says that exact same sensor is Downstream rear:
Amazon.com: Denso 234-4626 Oxygen Sensor: Automotive Amazon.com: Denso 234-4626 Oxygen Sensor: Automotive
So i dont know which to buy lol.
Old 12-14-15, 07:18 AM
DreaMzZ
DreaMzZ's Avatar
Can the same sensor be used for upstream and downstream?
Old 12-14-15, 07:11 PM
1997Soarer
1997Soarer's Avatar
Yes, but the wiring attached to it will be either be too short or too long.
FYI I'd trust the Denso website before I trust a seller on amazon
Old 12-17-15, 12:00 PM
Kris9884
Kris9884's Avatar
Yeah its the front oxygen sensor on Bank 1. Here's your part # : 2344630
Click on "Part number search" and enter 2344630 - Buy the Denso brand and you're all set..
https://www.rockauto.com/
QLex300 (10-11-22)
S160dre
08-11-16 06:36 AM
Max9911
28
05-12-15 08:49 PM
ADENNARD
05-21-13 06:27 AM
Joss350
01-15-13 11:09 AM
mortirius
ES - 5th Gen (2007-2012)
07-28-12 03:40 PM
Quick Reply: Need help on which part to order online
