1jzgte swap from chaser into 93 sc300 any insight
Hi guys i recently bought a 1jzgte swap for dirt cheap only reason was because its from a chaser no harness just auto ecu came with it and auto trans with trans harness.
Now im planning on swapping it into my factory 5speed lexus sc300 1993 i just have questions as in whats needed
what do i gotta change
can i use some of my 2jz parts
any links to other post will be awsome so far all ive researched and kinda know are
water pump from a 2jz
power steering resivoir from a 2jz
fan and clutch from a 2jz
serp belt
time belt neds to be replaced using one off a 80s izuzu trooper with the 2.6l
thermostat from a 2jz
front and rear main seal from a 2jz
1jz gasket kit reccommened but is it really needed?
supra tt radiator upper and lower hoses
mk3 supra throttle cable
i will be using my w58 trans for now and later going r154 or shouldi just sell my w58 and do it
main parts are converting the oil pan from front slump to rear slump
do i ave to buy the kit from driftmotion for 599 or can i use the ne from my 2jz?
driveshaft can be made using a mk3 supra front shaft and my 5 speed rear shaft
and the WIRING HARNESS im thinking of buying one online from CHASE BAYS for roughly 1300
thats all i have
serp belt
thats all i have
serp belt
thats all i have
serp belt
thats all i have
what do you mean when you say any 92 - 96 throttle cable 4cyl like any toyota car?
and is this how you tap the oil pan im all new to this swap lol
http://my.prostreetonline.com/2015/0...rt-a-2jz-sump/
thanks man
thanks man
Tlaurin3
Performance & Maintenance
05-09-18 03:44 PM
