Which fan blade to use on Soarer (JZZ30)?
I hit a racoon and smashed the radiator, AC condenser and fan blade. Insurance will cover it but they cannot get Soarer parts since it is an import. After a long search, I am pretty sure the Soarer and SC300 have the same radiator and AC condenser. Please correct me if I'm wrong. But it looks like the SC300 fan blade is a bit longer than the Soarers. So is there any other fan blade I can get? Maybe from a MK4 Supra TT?
1JZ fan clutch uses 1JZ fan blades
2JZ fan clutch uses 2JZ fan blades.
Blades aren't cross compatible. They have different diameters and the bolt holes don't line up. However, fan clutches ARE compatible. So you can put a 2JZ fan clutch (with fan blades) on a 1JZ engine, and vice versa.
If you just need the blades, and you have a 1JZ engine with original fan clutch, you will need the 1JZ blades.
stockhatch
Performance & Maintenance
15
09-27-13 11:05 AM
xspsi6
05-03-13 08:40 PM
