92 SC400 Timing Belt/Kit $800
Old 02-19-16, 11:22 AM
Sactolex
Sactolex's Avatar
Default 92 SC400 Timing Belt/Kit $800
sc has 91k on it, all original parts.
Local shop will do timing belt kit including water pump, hoses, tensioner, parts and labor for $800.
That sound reasonable?
Old 02-19-16, 06:18 PM
LEXXIUM
LEXXIUM's Avatar
That's a good price, depending on parts used, if you get an original Toyota water pump, gates timing belt kit with tentioner and pulley, then you got a great deal!!
If not original parts , you'll be doing the waterpump again, I can't comment on timing belts, but yeah the price is good...
Toyota dealers usually charts in the range of 1100-1200 depending on the dealer to do all the above
Old 03-04-16, 07:41 PM
Tru3dL
Tru3dL's Avatar
Sounds like a fair price, but why not just order the parts and do it yourself? You'd be surprised it's not as hard as you think
Old 03-04-16, 07:54 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
That price sounds fairly cheap. Just make sure the mechanic is one you trust. Personal experience, used a mechanic to replace some major engine parts on one of my vehicles and the mechanic put something on backwards which caused a rod shoot through the bottom of the motor.
carmaster1
05-27-18 02:51 PM
Wolverine2
04-24-18 09:34 PM
UGAALF
09-16-13 01:13 PM
k311in
02-24-11 06:29 PM
sorka
Maintenance
06-01-08 01:13 AM
Quick Reply: 92 SC400 Timing Belt/Kit $800
