Oily Steering Rack boots
When I read your previous message I thought you were asking why to use ATF instead of regular PS fluid.
The brand of ATF shouldn't matter for ps as long as it is a dexron-type fluid.
I use oem ATF because the price difference is negligible to me. I pay $4.69 a quart for oem T-IV.
I think you should be able to find a quart for closer to $5 online if you're willing to buy a case of 12. $10 per bottle is just ridiculous. The list price for 1 qt is only $5.61.
Go to www.myLparts.com and look up part number 00279-000T4. They charge 12 bucks for shipping, and you should be able to use the club lexus discount to get 10% off. They're a forum vendor, so you'll have to look up the code (I don't remember what it is). With the 10% off it works out to $5.09/qt. If you need other parts, then they offer free shipping over $150 which brings down the price per qt even more.
I use Toyota T-IV because my transmission requires it. It's convenient that I don't have to keep a separate bottle just for the P/S. Besides, it's not like you need gallons of ATF. A single quart should be enough to top off. If you need more than that, then you have a bigger issue to address than the $1-2 difference.
I understand your view but when you're on a tight budget and you have leaking rubbers (only on one side of the steering rack) standard fluid is not going to stop the leaks. The product I mentioned is a rubber treatment I believe which has allowed me the luxury of not having to fill the SP reservoir every week or so. I got sick of hearing the pump noise wind.
I should add that I also did the mod on the SP that removes the vacuum hose off the engine. Doing this stopped the white smoke occasionally coming out the exhaust which was also using the oil from the SP reservoir. ( I originally thought I had an engine problem e.g. worn valve guide etc.)
I still have to address the problem but it has given me breathing space.
hookem59
05-10-09 10:33 PM
