Help electrical ghost
Ok so here is my situation which will cause me a delay on finishing the interiors.
POWER WINDOWS
Got schematics tested the relay is good
On the driver side power goes in and out the switch driver window works fine
Passenger window will not work up or down on the master switch power is available with window lock up and no power with window lock down. tested the passenger side window lock works fine.
on the passenger side the power goes in on both wires to the motor green and white for down red for up
connected the motor and only goes up not down
switch the motor to the driver side and goes up and down
electrical experts some help please
POWER WINDOWS
that will be break in the circuit... We have power going into the switch , so yes power is going through the door jambs... actually power goes to both wires into the window motor up and down.
the motor when connected only goes up not down on the passenger side
I have two switches for both sides 1 extra master and 1 Passenger same problem.
Well I stand corrected , My neighbor help me troubleshoot and gave up LMAO. You were right at first I thought cant be we have power going to the motor.
Well I kept thinking and decide to check the harness.
Started at fuse box and went on wire by wire....
Found the damn wire (Red and Blue) driver side no continuity.
ripped her out fix it and that was it.
Thanks for the response I guess I just need to stop and take a break..
