can't peel out, have a question
first off....WTF why are you trying to act stupid and peel out and ****....second just becareful when you do it don't fawk up your car....try reving your car in neutral and drop it to drive.
I'm not going to neutral drop my car. lol
Oh, yeah. Also I was in KC and I had to floor it to get onto the free way. It got up and goin pretty fast, but the check engine light came on. I just reset the ecu and it went off, but could this be a sign of anything?
Nope, I didn't pull the code.
Ive set the check engine light off before from flooring it. I could do it again.
Both the traction control and check engine lights were on.
Should I go try and get the code from it?
Will
Will
i N droped my moms ES and chirped the tires i realy dont care about messin it up cause it goes back in nov. on lease but it dint sound real good when i droped it(defanly wouldnt do it again or until the last day we have it). just get a litle spray like a 50shot and take your trany to a trany shop and have them beef it up if they can(sombody was talkin about that on lexus pros boards)
Have been having the same problem lately, it just wont spin them. I have 18" wheels, but when I first put them on I could spin out from a basic flooring it, now I cant even brake stand. I am going to start tuning today. ? Do the wires need to be changed at 135K or just plugs, cap, and rotor?
i have a sc300 5 speed and i can't peel out either. my friend dropped it from 4 then 5 then 6... then i smelled roasted clutch for about an hour and had to shell out 400 bucks for a clutch yesterday. Never let your friends drive your car... Also how do you guys read the codes that the ecu is making? Where does it show codes?
Hmmm, you shouldn't have a problem lighting up your tires especially with the TC. Stock, the car can somewhat peel out without power braking (Even the 250hp 92-94s) Single stripe though.
How does your TC behave. Give it some light throttle. Does it seem as though there is almost no power until it hits 3200 like it should?
Redo the maintenance I guess. There are so many things that could be wrong. Clogged air filter, dirty injectors, dirty spark plugs, loose wire causing one or more cylinder to not fire, loose vacuum hoses, etc.
HELP
is the rotor in the distributor the same as the ignition coils? and if its not can someone post a pic with the ignition coil circled(ON SC300). Because i want to clean the ignition coil but have a new rotor , so if its the same thing then there is no need cuz its new.
