Titan Cams 280 Pros and Cons
Building my 2jzgte non vvti motor slowly, I got several questions:
1. Pros and Cons of running 280 cams on a street car? Head is rebuilt with 80lb BC springs. Guy locally is selling a set of used titans 280 for cheap. Goal is mid 600hp. Any input on this? Cons besides idle?
2. I want the car to response well, would 280 cams hurts spool? (I know thats mostly turbo dependent, going to run either a 6466 or a SXE 63mm on a log manifold with QSV)
Thanks.
Thanks.
Lex is right for 600 you can use the stock cams or 264. 272 would even be a bit large for that 280 is way too much since it moves the powerband to the right its going to seem like it spools slower but then make more power at the very top. if you want response keep with the smaller cam.
