Changed fuel filter, car won't start
I changed the fuel filter on my sc300 and now it won't start, everything is plugged in correctly but no luck. Suggestions? Thanks
Lol yeah I'm sure, triple checked that part. It ran fine before the filter change but now it doesn't want to start. I also don't hear the fuel pump turn on anymore and when I removed the filter to see if it was clogged or something it didn't squirt out fuel like before
Yes i did cycle the key and nothing, fuses/relays are new since i changed them. Im 100% sure its the pump that gave out since i tried to turn it on and it worked but only for a short time since i messed with the pump connections in the tank but now its back to square one. But i ordered a new pump which will get here on thursday
Have you tried bypassing the fuel pump ecu and supplying voltage to your pump directly? You should be able to accomplish this through your engine bay diagnostic connector
