93 SC400: No Crank, No Start
Hey guys. 93 sc400 with 94 1uz front sump. A few days ago the engine just cut off on me. It gets power to cluster and lights but no crank. I don't even hear the starter click upon key turn. I have e fans wired to ignition and they don't turn on either. I don't hear the fuel pump either. I've already checked the EFI fuse and relay and they are both good. My friend jumped the starter and it cranked but no start. So I know the starter is good. ECU is a rebuilt unit by tannin electronics so it can't be that either. A lot of guys on Facebook are suggesting it might be a disconnected starter plug. I'm just livid right now as I just got it back from being worked on. Any input is appreciated
you can check your starter easily by jumping these two. just stick a paperclip in there and it should crank, if the key is turned all the way to on, your car will start as well. check absolutely every single fuse. i drove my car with wires run to a switch from that relay for almost a year and one day rechecked all the fuses and it fixed it somehow, no idea what fuse fixed it.
spooledx2
Performance & Maintenance
12-16-09 06:05 PM
ScottURnot
30
07-07-08 02:15 PM
