NA-T Questions?? Ask the Guru
#931
The AEM V1 and V2 can run the stock ignitor and coil without any changes. The wiring above is only needed for the oem GTE ecu because it looks for the newer IGF signal that is returned from the newer ignitor (TT or ds62/dh61).
The AEM ignores the IGF signal so it does not care what ignitor or ignition system you have. Just follow the settings for the Non turbo box it should already be setup for the stock coil with the stock single IGT wire going to the ecu.
#932
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_0618_f051eef7523f4b176c157b8575639020a305f0c4.jpeg)
Thanks for confirming. I’ve been trying to run this Gs300 on the Tt mod but been unable to get it to start. It’s currently connected with the following below. With my power goals the ecu mod will be fine. Any input you can provide is appreciated as always. Black/red wire- coil 1 Black orange- B+ Black- tach Green/white- IGT Green/yellow- IGF
#934
gonna run through it to confirm. The IAT & map are there, running 550s w/ AFC. I’ll will circle back if there is any progress. Thanks again
#935
Hello! Im new both here and to the car community. First Ali, ur doing amazing work helping us out <3. Tho I do have a question, I have two cars right now and Im not sure what I should do with one of my motors. I have a (too) rusty 2001 IS300 with a good motor (which iv pulled from the car) and a 1992 SC400 with a blown up motor. Iv seen your 2jz NAT sc400 guides, however I was wondering if it was possible (or even worth it) to attempt to swap my good 2JZ GE (keeping it NA as im thinking of daily driving it to college) motor into my SC400 or should I just sell the 2JZ? My problem is that my motor im trying to swap is the VVTI version of the 2JZ and the car im trying to swap it into is the OBD1 early model of the sc400.
Much love from Canada!
(we never got the sc300s
E46CT
05-24-24 04:54 PM
