Bad Fuel Pump/Very Hot EFI Relay?
Old 06-21-16, 04:44 PM
Ozzzzy
Ozzzzy's Avatar
Default Bad Fuel Pump/Very Hot EFI Relay?
I had a problem with the fuel pump running after I shutting off the car. I found the relay wasnt working so I replaced the relay. I started having problems and I went to check the relay and it was very hot. Ive done the 12 v mod. The car is a 95 300. I recently changed the spark plugs and the idle is high but I thing thats from replacing the TPS and I THINK and placed it proprely. Can the fuel pump going bad cause this?
Old 06-24-16, 04:31 PM
bigwhite
bigwhite's Avatar
EFI relay will normally be very hot to the touch. Also tps adj. does affect idle.
MoncefGS
Maintenance
06-12-13 03:01 PM
SC300_704
11-12-12 06:51 PM
SCgonecray
08-20-12 09:20 AM
nhlrules8
12-11-09 01:19 AM
klepto2
12-04-09 03:36 PM
Quick Reply: Bad Fuel Pump/Very Hot EFI Relay?
