W58 Rebuild Kits?
This one:
http://www.driftmotion.com/W58-Rebui...o-p/dm1758.htm
However I would double check by calling Driftmotion and verifying that this kit works in both the 1992-1994 SC300 shifter extension housing W58 as well as the 1995-97 SC300 and 1993-1997 Supra NA "Tripod" W58.
The way DM's description is written it seems to refer to the tripod versions but it could be both.
This one:
You could also do this by taking the car to a service shop, putting it up onto a hydraulic lift and inspecting the upper rear section of the W58 transmission. It should be easy to see if the shifter apparatus is in a fully enclosed casing that extends slightly over the tailshaft or if it is the tripod type which has a metal cage enclosed around a rubber boot covered piston-like protrusion.
xspsi6
SC- 1st Gen (1992-2000)
08-10-11 12:54 PM
