sc300 stuck in park
Old 07-07-16, 09:00 AM
higgy69
higgy69's Avatar
Default sc300 stuck in park
about a month ago my battery was to weak to start motor, just barely would turn over , so when i went to push it out of garage so icould jump it i could not get it out of park. tried everything i could think of, but ended up calling tow truck to come out and jump it for me( my cables not long enough to reach.) once it got started went into gear fine, but since then it has locked up a few times now when i first start car? i will shut it off and back on sometimes that works or i tap pedal or wiggle / jiggle stuff , mixed results . once i had to leave it on the street & came in morning & worked fine? all my brake lites work? im lost i replaced battery same day it first died
Old 07-07-16, 09:30 AM
t2d2
t2d2's Avatar
I'm not sure what would be causing that, but there's a release button on upper left portion of the shift bezel to get it out of Park without the key in the ignition. Some of them have a partial blanking plate that you stick the key in to press down underneath.
Old 07-07-16, 10:29 AM
higgy69
higgy69's Avatar
thanks...i just figured that out yesterday....while i was trying to troubleshoot problem. im thinking maybe in the ign. switch . or i heard that there might be some kind of sylinoid beetween the brake switch and shifter lock.? would be nice if i could find some schematics or detailed pictures of those systems.........
Old 07-08-16, 06:16 AM
gerrb
Super Moderator
gerrb's Avatar
OP - when you press the brake pedal , it activates a switch on the side of the shifter which locks the shifter in PARK position. If that switch is bad , that shifter will not move. Usually can be repaired, just disassemble and clean up. Check my build thread. I once had a problem with one of my SCs with regards that park lock switch.
https://www.clublexus.com/forums/bui...v-toys-93.html
here is the switch on the right side of the shifter
On my end I had to clean it up and straightened that metal pin, then reassembled it and things where good again
Old 07-08-16, 04:17 PM
higgy69
higgy69's Avatar
just saw your reply....it looks like my LOCKOUT BYPASS SOLENOID went awol...
Old 07-08-16, 04:20 PM
higgy69
higgy69's Avatar
was kind of a hassle digging it out of there ..........hopefully thats it ..if not i will definately go with your suggestion....thanks for replys.......(i need all the help i can get
Old 07-09-16, 05:05 AM
gerrb
Super Moderator
gerrb's Avatar
yeap , that is also possible SHIFT lock Solenoid , or even SHIFT lock ECU or as mentioned that SHIFT Lock Control Switch I mentioned above.
Old 07-09-16, 03:06 PM
higgy69
higgy69's Avatar
well i'm going to have to wait a few days ....ended up having to order that solenoid from somewhere not here....
Jetstream
11-20-18 10:57 PM
dogbitdude
03-26-18 08:02 AM
nks979
IS F (2008-2014)
30
01-13-16 11:58 PM
aburnett2
07-30-14 07:46 AM
FinsIS250
10-03-12 09:18 AM
Quick Reply: sc300 stuck in park
