AT to MT!!! On my sc4
Old 07-21-16, 10:06 AM
Datsjonz
Datsjonz's Avatar
Default AT to MT!!! On my sc4
I need some suggestions. I have a 94 sc4 and yesterday coming home as I slam my gas peddle my transmission started acting up. So I'm looking into swapping it into a manual. What would be the cheapest way to go? What parts do I need besides a manual transmission. Or would it be cheaper to rebuild mine? thanks!
Old 07-21-16, 11:00 AM
scsexy
scsexy's Avatar
Cheapest would be find a used auto and throw it in there for less than 500 if you do it yourself.. Doing a manual swap isn't cheap especially with that motor that was never offered with a manual transmission.
Old 07-21-16, 11:02 AM
Datsjonz
Datsjonz's Avatar
Originally Posted by scsexy
cheapest would be find a used auto and throw it in there for less than 300 if you do it yourself..
300?? Really??? Man that's not bad at all!! Thanks!
Old 07-21-16, 04:46 PM
t2d2
t2d2's Avatar
I've seen 100k mile auto trannys for sale here for $100.
It's ironic that auto usually costs more than manual on two otherwise identical new cars, but they go for dirt cheap years later while used and abused M/T's fetch as much as the entire car in many cases. Supply and demand at its finest.
Old 07-21-16, 05:19 PM
Biddles
Biddles's Avatar
^Yea the market is crazy, once people found out 5 speed SC3's aren't common the price for them has tripled. Guy in my area has a 96 that looks like every body panel on it needs work and every piece of interior needs replacing, along with the engine, but since it's 5 speed he's at $6K...
Old 07-21-16, 05:52 PM
pogoism9
pogoism9's Avatar
Our transmissions are so cheap because they can typically go 3-400k miles
Old 07-21-16, 09:17 PM
CatManD3W
CatManD3W's Avatar
You can find deals out their......
W58 is probably your best bet is staying NA.
Old 07-22-16, 05:30 AM
Studiogeek
Studiogeek's Avatar
W58 is probably your best bet if staying NA.
And MAN would up the "smiles per gallon" tenfold.
A manual 1UZ is one of the finer things in life......
If you can at all afford it, do it and don't look back!
That said, another auto is way cheaper.....
Old 07-22-16, 07:27 AM
Deegee
Deegee's Avatar
Lets see, you would need to swap:
Tranny (w58/w55 would be cheapest)
driveshaft
pedals
tranny mount
1uz to w58/w55 flywheel adapter
new clutch (recommended)
I believe these are the big things, there may be other little odds and ends that I'm missing.
Old 07-22-16, 01:43 PM
Datsjonz
Datsjonz's Avatar
Thanks guys for all the info I'm going to see how much I have to spend.
Old 07-22-16, 05:50 PM
Biddles
Biddles's Avatar
driveshaft
pedals
tranny mount
I'm sure there's an answer on the forum somewhere, but in my 96 would I get a CEL for doing this swap if I did it legit? I know some people get codes they can't get rid of and never pass inspections again... What about ECU? I've been here forever, but I've been more focused on motorcycles for the last year or so. Starting to really get back into the SC stuff again.
Old 07-23-16, 07:03 AM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Default Cost
Borrowed item list for Deegee
Tranny (w58/w55 would be cheapest) $900-1400 used ... new ~2500
driveshaft $50 - $150 [local vs shipped]
pedals $350 - $450 if you include the master cylinder.
tranny mount ?
1uz to w58/w55 adapter + flywheel + clutch + slave hydraulics $1200 [multiple options] ... $1600 is most likely
misc ****, boot, oil seal, etc $150
I had set an expectation of about $2000 and have realized that I was way off.
Labor not included.
Salim
ZVizeman
RC - 1st Gen (2015-present)
06-20-18 10:13 AM
Stiffler
Performance
48
09-20-11 07:32 PM
lxsis250
05-15-11 11:47 AM
zuni
09-11-08 03:46 AM
jaymode
11-19-02 07:28 PM
Quick Reply: AT to MT!!! On my sc4
