99' SC300 5 speed swap vss conversion question
Hey Guys, I am on the last leg of finishing my 92 W58 5 speed trans into my 99 SC. The trans has a 3 pin mechanical VSS and the car has (2) 2 pin vss sensors. Is there an adapter or a way to wire up the 3 wire mechanical vss to work with the 99 SC wiring?
Sorry I don't have an answer for you but have you looked up the 1998 SC300 to W58 M/T conversion threads by Cartmill? He successfully got his swap working, sensors and all. I do believe he solved the VSS wiring as well as his neutral signal and backup light signal. His solutions should work directly for your model year since he was also converting a '99.
Here are his threads regarding the W58 swap into his 1998 SC300:
https://www.clublexus.com/forums/per...up-lights.html
https://www.clublexus.com/forums/per...ode-p1780.html
