Picture request: 96+ CA or 97 5-Speed throttle body
Hello,
Trying to diagnose a weird issue where idle won't return to 750 after driving around. I suspect there's something wrong with my TB itself beacuse the TPS is new and calibrated, and all vacuum lines are ok. IACV was disassembled and cleaned and tested according to manual.
I'm asking anyone with a 96+ CA Spec 5-speed or hopefully a 1997 actual 5-speed to please take multiple detailed pictures of the throttle body including the throttle cable from multiple angles with flash.
The reason I'm asking for those years is because the TB was redesigned from 1992-1995 or 1994 and had a different spring system and lacked the air assisted valve for the injectors.
Thank you much - I tried asking in the 120 thread since that would be the best place for this question but it was deleted.
bbqness
07-08-12 03:27 PM
