upper power steering hose part #?
Well shoot, I fixed the main leak from the hose, only to discover another one underneath the reservoir that may or may not have been there before.
Screwdriver is pointing to the fresh oil.
I'm guessing that's the high pressure hose fitting, although it seems like the oil would be travelling uphill from ther to where it's collecting, so maybe it's leaking from the bottom of the reservoir itself? I'll have to dry everything again and feel around for the source.
I wouldn't be surprised if I damaged it in trying to get that 9.5mm hose on. It took an insane amount of force to do so, and my forearms were literally cramped up for days. The reservoir felt plenty solid to brace against, though, so I soldiered on.
I'm mostly seeing LS400 info for that part # (saying it goes between the reservoir and pump), but Ali does have GTE / SC400 stuff I don't quite grasp the full context of, which includes it along with a diagram:
https://www.clublexus.com/forums/sc-...ml#post8871554
Is that the same thing you were thinking, or is there a different one for the SC300?
Its the same O-ring for both setups. Looks like yours needs to be replaced.
Try and get as much PS fluid out of the reservoir before removing as it will all pour out when you lift the reservoir off the base.
counteru
02-02-20 12:40 PM
dwebb99
Performance & Maintenance
23
05-04-15 08:46 AM
