Going NA-T in 3 weeks...
#46
Originally posted by SC300T
Perhaps someone like Angel can chime in on his timing settings on the AEM for reduced compression.
#47
vpc and injector size
So from what can tell if you choose to go with a VPC (that's my plan) you need one for a MKiii supra. Now I heard that NA 2jz injectors are high impedance injectors but I just read that MKiii injectors are low impedance.. What injectors do I need in using a vpc high or low? I want to go 550's but I would rather have 600 something cc injectors. I only see 550's chips for the vpc and nothing more. If anyone knows where to get bigger chips let me know or something. I have almost everything ready to thorw together. Also, what is the best timing retard device? And one more thing.. Who makes a datalogger of some sort for these cars? Is turboing a OBDll car a pain? I red that it could cause problems but what kind?
Thanks
Thanks
#48
Originally posted by tt1520
Lex,
Yep...8910 is the one I have. Good luck with your setup...When are you getting your turbo kit installed?
Lex,
#49
johnyboi.....You dont have to "Trick" our ecu's from detecting boost. No boost cut controller like the TT's.
You really should do a little more reading up before you take the plunge. From your question here and in another thread, it seems that you might be a little confused. Do a quick search and some reading. The information is there....and there are many here that are willing to help you out. Dont take this the wrong way, it just seems like your a little confused.
gadgetSC-t
gadgetSC-t
need2boost
SC400 / 300 Classifieds
30
05-08-14 09:42 AM
