oil catch can
If you are concerned that you might need one, swap in a new PCV valve and buy one of those small oil catch cans and put it on the fresh air hose to the valve cover.
Here's an example of the small "catchcans" out there.
http://www.jegs.com/i/JEGS/555/52205...h5lBoCqjzw_wcB
It holds a little more than an ounce
If you find that your engine fills this up every couple days, then you should look into getting a larger catch can setup. Also, if this is the case, you're getting a lot of blowby and your motor is old and worn
