climate control not working not fuses
Old 01-24-17, 03:42 PM
mmac0405
mmac0405's Avatar
Default climate control not working not fuses
bought a new sc300 with 2jzgte, heater core wasnt hooked up, there no heater control vavle or ac lines and my climate control with not turn on check every fuse everything good no pennies or metal stuck in sock. the guy hooked the power for the aem gauges off the plug that powers cig lighter only thing that looked funny. i also check plugs on car i have power off the plugs and also enuff voltage the car is butched up without a doubt even swapped working climate control in and it still does not work where is the ground for climate control? any suggestions im going nuts ! ive searched did not find anything that help
Old 12-15-19, 04:37 PM
03GS2JZGTE
03GS2JZGTE's Avatar
I apologize for the revival of this thread, but I have the same exact problem. GTE and cd009 swap, al fuses good, cig lighter works, no coins in cig lighter, has power to connectors, swapped in working climate controls....still no power to the climate control..
did you ever get this resolved? If so, please help. Thanks
Old 12-16-19, 08:15 AM
oldManTan
oldManTan's Avatar
check the wheel well harness
Old 12-16-19, 08:32 AM
03GS2JZGTE
03GS2JZGTE's Avatar
I’ll check that. Anything to look for beside damage to the wiring? I believe the previous owner relocated the driver side wheel well harness...I’ll double check though.
wirelesstj
SC- 1st Gen (1992-2000)
14
03-16-14 08:35 PM
CJspoppie
RX - 1st Gen (1999-2003)
10-03-12 07:27 AM
lexusls95
09-22-10 05:03 PM
bkbw
05-25-05 10:46 PM
Quick Reply: climate control not working not fuses
