Bouncing Temp gauge needle
I switched clusters a couple of months ago. The new cluster has 98,000 miles and came from the same year and model-1992 SC400.
It has nice needles. I replaced all the cluster bulbs before installing it.
I took a trip last month and noticed when I hit hard expansion joints the Temp needle went to Hot. I've taken the cluster out of the dash still attached to the harnesses. With the engine running, I tap the side of the cluster and the needle goes up, then tap again and it goes back to normal. Is this a bad Temp Gauge?
I've got my original cluster and can install the Temp gauge and switch needles, does this sound OK?
I was reading a previous post that the Temp Sensor wire is in the center harness plug, is that correct? Something about 330 Ohm resister?
Any help or suggestions will be appreciated.
Thanks.
Thanks.
Elle33
IS - 1st Gen (2001-2005)
04-06-17 06:48 AM
