What wire for reverse light?
Old 02-22-17, 05:54 PM
Returd
Returd's Avatar
Default What wire for reverse light?
I want to grab the reverse light wire to turn on my rear view camera. I'll grab the wire at the passenger side connector most likely. It'll save me some time pulling the tail light to discover fro myself if someone has he diagram handy.
Thanks
Old 02-23-17, 08:00 AM
Bankswood
Bankswood's Avatar
I recently Had to find that wire. I actually found a red wire (it might have a black stripe) and used a power prob light to confirm it was the reverse light. Just take the power prob light (they are cheap) and stick the prob into the connector and use the other end for a good ground. Turn the key to the on position (don't start the car). Put the car in reverse and check the prob for power,
Old 02-26-17, 09:31 AM
t2d2
t2d2's Avatar
I haven't hooked mine up yet, but it should be red/blue (+) and shared white/black (-).
Old 03-17-17, 05:46 PM
Returd
Returd's Avatar
called the dealer and was informed for my 92 it's red with black stripe. That's the wire leading to the connector, changes color at the tail light side of the connector. I tapped into the pin on the feed side of the connector (red/black)
Old 03-18-17, 12:24 AM
t2d2
t2d2's Avatar
Out of curiosity, did you also have a red/blue? I'm guessing it's one or the other. Or, it could be either they're too close to tell apart when dust covered and in poor trunk lighting, or "red/bl" is too ambiguous to keep straight in a game of telephone.
Old 03-18-17, 08:49 AM
Returd
Returd's Avatar
I just checked and yes, the tail light side of the connector is red/blue stripe.
to clarify, reverse light + at tail light connector
feed side of connector red with black stripe
tail light side of connector red with blue stripe.
caveat, I have no tested but got the red/black info from the dealer
Old 03-18-17, 02:29 PM
fixme1too
fixme1too's Avatar
Yes its the Red and Black wire... It also can be found under the gear shifter if you remove it.... Its a lot closer than running a wire all the way to the trunk.
Old 03-19-17, 05:48 AM
Returd
Returd's Avatar
now you tell me.......
I had to run the camera wire to the back anyway and the interior is out so it wasn't a big deal, but good to know.
shonn
06-01-15 08:33 PM
Biddles
SC- 1st Gen (1992-2000)
19
06-02-13 02:12 PM
Emilio253
17
10-25-11 08:06 PM
corkycal
14
12-02-07 07:35 AM
BA_GS400
07-26-04 12:09 PM
Quick Reply: What wire for reverse light?
