Leaking PS fluid after line change/iac delete
Old 03-14-17, 01:11 PM
93sc400nm
93sc400nm's Avatar
Default Leaking PS fluid after line change/iac delete
Well I replaced my high pressure powersteering line with a 3SX performance line which deleted my IAC. I also replaced some return hose sections and put in a new reservoir. I filled the powersteering fluid up and turned steering wheel back ten times to try to remove air...got the noise down some...took the car for a drive and after a minute powersteering fluid started gushing out of the reservoir!
What did I do wrong with the filling process??? Correct filling procedure for 1993 sc400 is what? Could it be that I have a bad pump?
Thanks! after 4 months on this project changing everything from suspension to ignition parts 3 of the 4 months has been this dang power steering leak, any help appreciated.
Old 03-15-17, 06:12 PM
93sc400nm
93sc400nm's Avatar
Just tried fixing power steering again. I can get it to where it drives great and doesnt make a sound when I turn the wheel...then after driving 15 minutes it all leaks out of the top of the power steering fluid reservoir.
I would like to add that I am using dextron 4 automatic transmission fluid is that the right fluid? They dont make dex 3 anymore...seems strange to use automatic transmission fluid
Old 04-04-17, 09:00 PM
93sc400nm
93sc400nm's Avatar
hey guys still have this problem and cant fix it...thought I would bump this thread since its been 3 weeks any help would be appreciated thanks
Old 04-04-17, 09:09 PM
Htony
Htony's Avatar
Being hydraulic system there ought to be a pressure relief valve or check valve in the line. Take another look at service manual. Same thing happened once on my
camping trailer tow truck. Cause was bad pump assembly. I found a replacement at the wrecking yard.
Old 04-04-17, 09:32 PM
93sc400nm
93sc400nm's Avatar
A lot of folks on here have blocked off the idle air control valve without any problems...putting the AN line in there bypassed this...so your saying a bad pump can cause fluid to gush out of the reservoir?
Old 04-05-17, 05:12 PM
93sc400nm
93sc400nm's Avatar
Thanks Htony I think I should just change the pump and see if that works
Old 04-09-17, 01:57 PM
LoudonMan
LoudonMan's Avatar
Went through this drama myself. Replace the pump suction line from the reservoir. It could be sucking air, like mine. Save yourself some grief and use a OEM curved hose.
tanstaafl
ES - 5th Gen (2007-2012)
03-06-19 04:04 PM
wkp
RX - 1st Gen (1999-2003)
11-05-18 05:13 AM
khailon
03-06-11 12:29 PM
ToyotaLexus
02-12-09 10:05 AM
robmck
SC- 1st Gen (1992-2000)
03-03-01 07:14 PM
Quick Reply: Leaking PS fluid after line change/iac delete
