2JZGE help
Hello friends! Im new to the forum and looking for some much needed help! Im in the process of transplanting a, what I believe is, a 97 sc300 2jzge into my 92 mustang. Well I just got the engine and harness and I need to eliminate some unneeded stuff, egr, abs, traction control, etc. There are so many wires that do absolutely nothing for my particular need... So my big question here is.. Has anyone stripped down one of these harness and had just the essential? If not thats ok i would just like some info to get me going in the right direction.. so some much needed wiring diagrams.. ecu pinout, all the connectors on the engine harness pinout would be amazing. Ive googled so many different things and they all seem to point me to this site. So lets see what we can come up with!
thank you
Zero
thank you
Zero
Welcome to the forum .
First i suggest reading the stickied thread which is a summary of different threads . Pretty sure a lot of what you are looking for will be there.
https://www.clublexus.com/forums/sc-...tart-here.html
Then the following thread will guide you were to start threads
https://www.clublexus.com/forums/sc-...d-deleted.html
Good Luck !
Good Luck !
