Canadian 92 SC400 DRL info please
I'm dealing with some signal/cornering light issues due to PO sloppy work. Does anyone know if the Canadian 92 SC400 came with DRL's (day time running lights).
I found some cornering light wiring butchery on my 92 that I'm reverting to stock using bits from my 93 parts car. I noticed the 93 has DRL relays but not my 92. I'm wondering if the DRL's were part of the butchery to my 92. If they're supposed to be in there it's going to be a bigger job to pull from the 93 and install into the 92.
heres the relays on the 93.
you can see my CDM SC with lights off so drl on
there is no way to turn them off
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/579x1024/imag1341_cffe358fd418d4ac01a5a72f455047db8dd39c9b.jpg)
I was incorrect in my previous post about DRL's and my 92.
I do have DRL's but through the projectors. I also have HID's in there that look to be stock as the ballasts are Lexus branded.
On a different note the OGS guys have said I've got the wrong HID bulb in there.
so 2 questions.
Is this a stock HID setup?
what bulb should I be using?
so 2 questions.
