Check engine code
Check engine code
Hey guys can someone give me a hand with the trouble code of 28. I got the check engine light yesterday on my way home, so I pulled the code form the car when I got home and it flashed 28. I have a SupraTT and checked the code in the MKIV service manual and 28 reads sub main O2 sensor is failing. I think the SC300 also uses the same trouble codes as the Toyota Supra since they are made byt he same company, but if anyone can tell me for sure what code 28 is from the SC300 service manual. Thanks
Guest
Posts: n/a
Answers can be found by using the search function.
It looks like your engine code means the #2 oxygen sensor.
Look here for reference. I found this answer by using the search function.
https://www.clublexus.com/forums/sho...ht=engine+code
nicos1
10-08-07 12:44 PM
