Odd electrical issue.
Old 04-23-17, 06:14 AM
TokinSC400
TokinSC400's Avatar
Default Odd electrical issue.
I have a '95 SC400 and on the way to work the other night, I lost all all power to the car except for the engine. I had no head lights, no power inside the car. Then after about five to ten minutes it clears up, all power returns.
Old 04-23-17, 07:13 AM
t2d2
t2d2's Avatar
Check your main grounding points and your wiring harness (for rubbing) through the front left wheel well, especially if the car is or has been lowered.
Old 04-25-17, 02:53 PM
TokinSC400
TokinSC400's Avatar
I've already moved the wiring harness from the left wheel well. I had to replace the battery but it is still doing it.
Old 04-25-17, 10:01 PM
t2d2
t2d2's Avatar
Did you unplug and reroute the harness, or cut and extend it? It sounds like you have a bad connection in there somewhere, although it could be a million other things. I would start by double checking that your mod held up.
Old 04-26-17, 08:32 AM
TokinSC400
TokinSC400's Avatar
I unplugged and rerouted it. I will recheck the plug.
Markysc4
SC- 1st Gen (1992-2000)
17
06-27-12 02:42 AM
cdvmagic
03-03-08 08:20 PM
ThomsonCharm
02-05-08 10:35 PM
DarKnight
02-11-07 05:17 PM
Quick Reply: Odd electrical issue.
