92 sc400 egr valve specs? electronic California emissions
I have code 71 and the Egr valve was stuck open so I made the delete plates and installed a 10k resistor in the Egr temp circuit and still code 71? No resistance specs
108 views and no responses? either no love or nobody else knows the specs? so far i have done this to the car 1 month of owning it.replaced fuel injector and fuel filter,hollowed out damaged cats,center resonator and rear resonator delete,caps rotors plugs wires,power steering high pressure hose,ecu caps and transistor replacement,(that was a fun night to say the least),diy cone filter intake for noise,ac retrofit,both interior door handles,both window regulators,steering rack,front upper and lower control arm bushings,front and rear sway bar bushings,replaced tps,cleaned and replaced bearings in my iac valve,diy egr block off plates with 10k ohm resistor,and most recently deleting the mufflers.(going to weld on some magnaflows or flowmasters on this weekend)i also have obtained a w58,clutch pedal,and front half of driveshaft as i plan on swapping to 5 speed.any help is very appreciated as i dont want to buy a egr valve if its not in use anyways just to clear my last check engine code on my laundry list of codes that i started off with.
Hey, i dont have a spec for egr, but can take a look for any details you need in factory manual for sc400 ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
i got a question to you, after deleting cats, do you have cel that complaining about cats ? Thx. Looking long time for the answer.😊
no need to worry about o2sensor codes.only code 71 the egr code. I have been searching for what controls the A19 pin at the ecu. It goes to the transistor that failed in the ecu.
your exhaust will be a little stinky but the sound makes up for that.
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_0013_967b9bfeae4a6a6d4bf2189614eef5d4d5f24558.jpg)
2003 tundra.the radiator is some race one for a Honda or something...friend gave it to me new in a box saying that I could come up with some kind of use for it.well a week later my oe plastic radiator cracked and leaked coolant and soon as I pulled in a parking stall(like it waited until right before I had to turn it off) lol.epoxy worked to seal it,refilled it and drove it back home to start brainstorming on some mounting ideas for the racing radiator for a different car a week prior. Made some aluminum brackets that accepted some energy suspension bushings I had and I am happy with it now
what a coincidence right?
The flowmasters are the way to go. 40 series single chamber, no tips. Sounds like a cammed out domestic. Ive the same exact setup
1UZFE_SC95
Performance & Maintenance
27
07-10-21 12:53 PM
72corolla
06-02-17 12:31 AM
