BFI pics...
Old 06-09-03, 07:43 PM
lex400sc
lex400sc's Avatar
Default BFI pics...
Just got back from LA and thought I'd share more detailed pics of the BFI as it is now (still incomplete)...
Old 06-09-03, 07:45 PM
lex400sc
lex400sc's Avatar
I had to relocate the HID ballast to underneath the subframe so that it wouldn't restrict flow inside the airbox. OEM ballasts are twice as big and have a limited range from the bulb itself due to the short cable..
Old 06-09-03, 07:47 PM
lex400sc
lex400sc's Avatar
Theblue stuff on the side is heat insulated foam. The box is pretty much all sealed when the lid goes on with the exception of some minute slivers between the lid and box.
Old 06-09-03, 07:50 PM
lex400sc
lex400sc's Avatar
Cut a new BFI out of 22awg steel instead of the cheapo Home Depot sheet aluminum. This stuff is more durable and sinks more heat...
Old 06-09-03, 07:52 PM
lex400sc
lex400sc's Avatar
I taped off the edges of the steel to help block off the small gaps between the box and lid and to help seal the edges once fastened. I will spray paint this stuff with black auto paint and maybe a clearcoat since it isn't "stainless" steel.
Old 06-09-03, 07:53 PM
lex400sc
lex400sc's Avatar
Some of my templates and first drafts...
Old 06-09-03, 08:35 PM
siniquezu
siniquezu's Avatar
Wow. Where did you get the steel? Are you gonna use the same piping you had before?
Old 06-10-03, 07:46 AM
ChrisK
ChrisK's Avatar
lex400sc,
I'm also interested in finding out where you got the 22awg steel.
Thanks,
Old 06-10-03, 09:26 AM
lex400sc
lex400sc's Avatar
Orchards Hardware or any metal processing factory.
thafox84
05-21-15 12:11 PM
daily400
General Classifieds
09-08-12 04:43 AM
8TREYLOC
08-31-11 07:37 PM
NVICTIS
06-25-03 08:32 AM
Din
SC- 1st Gen (1992-2000)
06-03-02 06:10 PM
Quick Reply: BFI pics...
