What amp fuse for IS300 fans (seperate)
Using IS300 fans in my SC, What is the correct size fuses to run for the IS300 fans? running both on separate relays so how many amp fuse do I need for each fan, I believe stock is 30A for both so does that mean 15A for each? If I know the watts as well I can calculate the correct fuse size
Any help thank you
Any help thank you
TwentyTen
11-11-06 03:06 PM
