Usdm to jdm swap 2jzge throttle cable?
I just noticed that there is no way to mount the bracket for the throttle cable on my usdm 2jzge on my jdm 2jzge (both non-vvti). The jdm one is set up to link to the left side of the car, where the usdm is opposite. It doesn't look like I can use the stock usdm throttle cable because it's too short... so what throttle cable should I order that will fit the jdm one?
I have a 92 manual sc300.
Thanks!
Thanks!
I decided to do an EGR delete to clean up the engine bay, which would mean having to do an EGR cap-off on the USDM Y pipe if I use it.
If I decided to just use the JDM Y pipe (which doesn't require capping off since there was no EGR to begin with), what throttle cable do I use? I'm reading online that a 94-96 Camry V6 throttle cable is good for swapping in a a JDM 2JZ-GTE, but what about a JDM 2ZJ-GE?
tampa mike
SC400 / 300 Classifieds
01-28-11 07:01 PM
