1995 sc300 1jz no spark?
Im to new to the forum to pm anyone been around lurking on this forum for a min. But anyways.
So im having an issue getting spark. Power to ignitor coils injectors starter. I have tested and found that b1 and b pins on ecu plug dont recieve 12 switched or constant. Crank position is in specs also. Anyone have any suggestions?
Welcome to the forum, Cody!
I've moved this post to our "Performance and Maintenance" section.
My apologies for not being able to help you with this question. I can only guess from my little experience with coil ignition systems... have you verified that the coil pack necks that go into the spark plug wells are not in any way cracked or compromised? IF so, usually cracked coil necks can be repaired with an insulator kit. Driftmotion sells one for 2JZ and 1JZ coils.
