help with 30-42LE (340LE) transmission wiring
Old 08-03-17, 05:10 AM
JoeU2
JoeU2's Avatar
Default help with 30-42LE (340LE) transmission wiring
hi, I have a 1GZ-FE jdm V12 engine, got it running in my engine run stand (with an Amp EFI MS3pro ECU), now I want to get the 30-42LE transmission wired up. I think it is the same as 340LE, 341LE, 342LE, but am unsure. I have a microsquirt transmission controller and a quad high side driver, I don't know the wiring of the 10 pin connector that connects to the solenoids. I guess that the two pin connector near the tail is the Vehicle Speed Sensor, and I think the two pin connector near the bellhousing is some kind of lock? I have figured out the connector near the shifter with a continuity tester, so it is no problem, but I don't know how to figure out the solenoid wires. I have ohmed it out, and I think I have found two solenoids connections that the other side of them goes to ground (pins 5 and 10), and I think I have three solenoids that I have both sides of the coil's wires (2&7, 3&8, 4&9). and I have two wires that don't show continuity to anywhere (1&6). can anyone help me with this? thanks in advance!
JoeU2
SC- 1st Gen (1992-2000)
07-31-17 04:36 AM
jehmin
Maintenance
05-04-17 09:52 AM
Quick Reply: help with 30-42LE (340LE) transmission wiring
