NA-T turbo coolant lines and intkae vacuum lines
I've googled several of these but cannot find much of anything surprisingly. If anyone has pictures of how they did their SC300 NA-T turbo coolant lines please share. Also, the vacuum lines that go to the intake and the bov would be helpful as well. Thank you in advance.
some people use the lines going to the throttle body, trace them back to where they come out of the engine and use those.
bov just gets a good vacuum source off the manifold. not sure what others you are talking about.
what turbo are you using and have you gotten it already? most na-t turbo's are large enough that they are only oil cooled, as in no coolant lines.
that makes it a bit easier and then you can just add an oil cooler to the stock system to keep the oil happier.
