negative camber help *From Those that have it*
I bought camber arms and toe arms.. I believe this will give me enough negative camber that I need but for adjustability and correction purposes is there anything else I should get to make the ride as good as possible? Post pics if you have the negative camber
Anyone who lowers more than 2 inches probly has some negative camber, more -= less tire life!!
I wouldn't do it again
Are you trying to correct your negative camber making your wheels straight or making your tire fit in the fender (by adding negative camber)?
while you're there replace rear sway bar links and check your lower control arms
