*help* 1st time lexus owner
so i have 2 completely dead cylinders #1  it all started when i disconnected my negative battery terminal to clean throttle body & maf then car started jerking at slow speeds, and misfiring, theres spark running through the wires, but they dont fire, the injectors wouldnt fire so i got used ones from the junkyard, still didn't fix issue,did compression test and compression is flawless,, so far ive fixed injectors , plugs,wires, driver side coil, maf sensor, cap and rotor, whats next?
lp_yang
17
04-26-08 10:56 AM
gobears
06-03-07 03:52 PM
