1JZ Swap Bypassing Wiring Extension?
I came across a thread that was suggesting that instead of extending the wiring harness/buying an extended one you can wire it in a special way. Supposedly if you drill your speedo hole larger you can reach it through there and wire it behind the radio. Is there any truth to this? I would post the link to the thread but I don't think I am allowed to post links yet.
Probably should have remembered it came from the supra forums, but to quote the posts:
"I would not recommend extending it. Just drill a whole behind the intake manifold and route it to the stock location through there."
"You must be pretty new to all of this because no one really extends their harness anymore. I wouldn't recommend it because you would have to add 200+ solders to your harness and tracing wiring problems with a extended harness can he hell.
If you have a car that has abs then get a hole saw and drill your speedo hole larger. If you dont have abs then their are a couple better places you can drill a hole around that area."
"Not exactly a shortcut way of doing it. Actually smarter and preferred by most people / shops who do these swaps. Me and my brother both had extended harness and bought new harness and routed it behind the intake manifold because it looks alot cleaner and less wiring headaches.
If you did your home work you would have found out that people have stopped extending harnesses a few years ago when driftmotion came up with the idea to drill a new harness hole and run the wiring behind the radio to the stock location.
Glad your car is up and running and this will be my last time posting in any of your threads."
1997Soarer (10-09-17)
Matt300ZXT
Performance & Maintenance
07-31-14 07:50 AM
B.Diddy
06-12-12 07:51 AM
