SC400 cluster capacitors - picture and values
First of all thanks to 1JZPWRD for following instructions:
https://www.clublexus.com/forums/per...-lighting.html
The above help me take out cluster and list the 11 capacitors. It would be good to know which one to replace for light again dark needles? (1995, SC400, 1UZFE)
1 - 10V 100uF
2 - 25V 470uF
3 - 10V 470uF
4 - 10V 180uF
5 - 25V 470uF
6 - 16V 10uF
7 - 10V 180uF
8 - 16V 47uF
9 - 50V 100uF
10 - 10V 100uF
11 - 25V 270uF
1 - 10V 100uF
2 - 25V 470uF
3 - 10V 470uF
4 - 10V 180uF
5 - 25V 470uF
6 - 16V 10uF
7 - 10V 180uF
8 - 16V 47uF
9 - 50V 100uF
10 - 10V 100uF
11 - 25V 270uF
goldsoarer (05-29-18)
I changed the 2, 5, 9, 11 ("high" voltage) capacitors, but needles remain dark. I understand that needles fault:
DIY Gauge Cluster LED Needle fix - Page 2 - ClubLexus - Lexus Forum Discussion
But now the clock and odometer backlight went out, both show the correct values but without lights, they can only be seen very close and very dim. Someone could help me which wires could have broken?
Found it! That was a wrong soldering (printed circuit interruption) on 5. (25V 470uF) capacitor:
Solution:
And now
Solution:
And now
Keeper of the light
Information has been on club lexus since 2003. https://www.clublexus.com/forums/sc-...-clusters.html
....and where all subsequent information has came from. Spent months detailing every nut, bolt, and part in them for full understanding so no cliff notes. It’s there if you want to learn.
skoles (10-08-17)
YODAONE
SC- 1st Gen (1992-2000)
05-02-17 05:55 PM
