Bw s363
Borg Warner Outlet
I'm starting to collect parts for my NA-t upgrade. I'm wondering if there is normally enough space behind the turbo to fit a 1.5" (thick) Marmon flange to 3" V-Band adapter back there.
I'm looking at this:
https://www.ebay.com/itm/3-to-4-Steel-Exhaust-V-band-ADAPTER-vband-V-Band-3-0-adaptor-Flange-CNC-3in-4/252292993121?hash=item3abdd59061:g:3DoAAOSwJcZWhChc&vxp=mtr
Seems to make it much easier to use a BW turbo.
So far, I've done the following:
GTE ECU mod
500cc Injectors
I've bought the following:
46mm Tial WG
SS v-band flange Dump Tube
Latest SS CXRacing 11ga Manifold
PS: Comments on my preliminary turbo selection (S363/68 T4 .88) are welcome also. I'm looking for quick spool and ~400-440hp. 95% Street use.
Thanks in advance
GTE ECU mod
500cc Injectors
46mm Tial WG
Thanks in advance
You may run into issues with using that adapter. The BW turbo hot sides are LARGE. Why not just use a Marmon to 3" pipe and just cut off the v band? Or, cut off the Marmon and weld a 3" v band in place?
I have a S366 with a Marmon->4" adapter welded to a 4" downpipe and it's a tight fit.
OK, second question. Would anyone here be interested in welding a marmon flange onto a 3" downpipe for me?
I only have a gas-less MIG welder which I don't think will work for this application.
you can hit up Dan@ FSM in Delaware he can do that for you. or maybe hit up Freed in MD
