high pressure power steering hose
Old 11-12-17, 09:52 AM
matrixgts
matrixgts's Avatar
Default high pressure power steering hose
Have anyone replaced their high pressure power steering hose?If so what was the cost for the hose and where is the best place to purchase it from.Thanks
Old 11-12-17, 08:42 PM
BiGEZ
BiGEZ's Avatar
I had mine rebuilt at my local hydraulic hose shop, cost me $60.00. They reused the ends and high quality hose, no issues after 3 years. I recently had them rebuild one for my SC400. AutoZone quoted me $175. special order the told me they were unable to get it. You can try RockAuto.com if you can't find a local shop.
Old 11-13-17, 07:40 PM
RXRodger
RXRodger's Avatar
Driftmotion sells one for around $60, includes the fittings you need. Easy fix, maybe 5 or 10 min job.
Old 11-14-17, 01:33 AM
KahnBB6
KahnBB6's Avatar
Received 1,239 Likes on 866 Posts
I think I changed my high and low pressure OEM hoses with new ones. I ordered mine from Lexus of Pembroke Pines (online) at the time.
The Driftmotion hose will work but it's not exactly the same if you compare OEM to their simple hose. I would have your original rebuilt at a pressure hose shop if you can't get the OEM part any longer. There is no reason to throw away the original assembly if all it needs is to have its rubber hose and pressure fittings replaced.
Old 11-14-17, 07:43 PM
RXRodger
RXRodger's Avatar
But it works just fine, it actually is better than the OEM hose.
Old 11-20-17, 05:33 PM
Returd
Returd's Avatar
got mine from rockauto for SC400.
It's two piece. Be cautious not to introduce any twist to the hose as it substantially reduces hose life.
matts6887
12-18-18 03:14 PM
grindin8o8
CL of Hawaii
07-10-09 03:31 PM
NorbertNip
SC400 / 300 Classifieds
12-19-05 11:40 AM
CompuMan
Maintenance
05-02-05 01:38 PM
sunny76g
SC- 1st Gen (1992-2000)
05-31-03 09:33 AM
Quick Reply: high pressure power steering hose
