SC400 AC and ALT wiring question
Hello all,
I am putting a 1uzfe, 95 SC400, into a kit car and it will have AC and will use a MS3pro ecu. I have the stock AC connector and having trouble figuring out what wire does what and want to make sure I am wiring it up right. I need to turn on the AC compressor magnetic clutch. The connector has the following wires.
Brown
Blue
Green with a yellow stripe
I would assume brown is ground and green/yellow is power, but not sure when I look at the wiring diagrams I see.
My next question is on the alternator connector to make sure the alternator will charge. The wiring on that is as follow and here is what I was thinking when looking at the charging wiring diagram.
White- power
Black- Power
yellow green stripe- goes to alt meter so not needed.
Thanks for the help as it is really is appreciated.
Troy
Brown
Blue
White- power
Black- Power
Troy
wanganstyl
Performance & Maintenance
05-10-09 12:29 PM
