Anyone done a 1GZ swap?
^ There's lots of rumors like these on the internet. Apparently there's a guy with a MKIII Supra that's 5 years into the swap and it's still not running yet.
I think there is one old Toyota with a 1GZ in it. But non-turbo. Somewhere in Socal. And there is one MKIV Supra here as well that is 1GZ swapped and twin turboed. I remember seeing vids of it going around fb a year or two ago. No dyno vids tho, just starting and idling vids
There are lots of small things that add up with this engine which is why it hasn't been done a whole lot.
For starters, it wouldn't drop into an SC chassis cause the SC needs a rear sump.
As far as I know, all the v12 century vehicles were front sump, so you would need to make a custom sump setup on the SC or go dry sump.
I remember reading that the oil pump is on the front part of the sump too so I am guessing it may need modification also for a rear or dry sump setup.
Then there is the dual ecu's which isn't that bad if you have all the factory stuff to reuse.
intake manifolds may have trouble clearing low hoods like the SC has, hard to say without trying it.
I think if you wanted to get a stock one in there it would be doable with some custom bits that adress the above plus whatever else comes into play.
If you wanted to get more power out of it, remember they are the vvti variant so I would guess they have the weak rods as well but don't know for sure.
If you were to build the bottom end I figure it would get pricey quick seeing as there is double of everything vs the JZ engine.
It would be cool to have one of those with a supercharger on it, maybe if the boost is low enough you could run it on the stock internals.
I read when top sercet did it they went through the whole engine to get it to hold the turbo power, but they were shooting for some higher hp goals.
This might be a good swap for a IFS toyota truck that could take a front sump, or a GS or IS that uses a front sump.
It's a glorious engine (basically two 2.5L 1JZ-GE's mated together) but very rare and expensive to swap.
Ali, when you say it's a "VVT-i variant" do you mean that the 1GZ could be using rods similar to the same ones found in the 1JZ/2JZ-GE from the factory?
I think Top Secret probably made their own custom oil pan to fit their 1GZ into a Supra MKIV's engine bay.
Thatfastsupra on instagram did/is doing a 1gz turbo build. He has had it running for a while, but now hes upgrading parts and doing a restoration of the whole car.
Here is one of his youtube videos about the car on his youtube channel for those who are interested.
https://www.youtube.com/watch?v=r8YmFmR3Xek
